Cob or brick & cement? First time build in Winchester, UK
  • bigdavenorcott
    • May 2014
    • 22
    #31
    Re: Cob or brick & cement? First time build in Winchester, UK
    Wondering if I've dropped a bollock with the size of my base. Link to UK forum here if anyone can throw some wisdom into the ring
      • 2848
      #32
      Gday
      Sorry that link needs a password
      regards dave
        • 2848
        #33
        G'day big Dave
        Had to resister to see your post so there's a reply on UK forum as well
        You just have enough room by my calculations...just. You forgot that the dome entry bisects the dome and takes a chuck out of that 28 in dome. by my calculations it adds another 3 to 4 ins giving you 14 ins in which to build your entranceway. With a brick length being 9 ins....close enough to a brick and a half worth to be perfect'ish.
        Now you got to remember Australia hasn't use feet and inch's for 40 years so the following should be checked.
        Dome internal width 28 ins dome, internal height 14ins, dome entrance with the 63 per cent rule should be near enough to 9 ins. dome entrance width at just a smidgen under half should be12 ins.
        Entrance way should be as big as possible in my book so using nearly all the width of a brick of the oven entrance at 4 1/2 ins should gain you an entranceway way width of 20 ins and a height of 18 ins.
        With the size of a 28 in oven on the slab you have 10 ins either side to play with... 4.5 ins for the 1/2 brick dome and 4 ins for a standard thickness of V-crete, leaves you with 1/12 ins of render or 1 1/2 in cut down brick. If you wanted to enclose the oven there is nothing stopping you from building outboard of your stand.
        Now I'm a visual person so If I can see it so much the better, so it was a whole stack of cardboard cut outs for me. you can lay the out on you stand and really get an eyeful of what you building. don't stop at the flat ones either a couple more showing the dome heights and even the dome entrance that will really show you how much it cuts out of the dome.
        Hope this helps
        Read more: Oops, there was an error! | UK Wood-Fired Oven Forum
        • bigdavenorcott
          • May 2014
          • 22
          #34
          Dave, you are a prince - that's amazingly helpful, thank you.
          We don't use feet and inches either, I just got into the habit when talking about wfos as it seemed like everyone else did!
          Cardboard it is - I'm the same as you, I reckon I need to see it.
            • 2848
            #35
            G'day
            Funny about that...
            Pay backs are a bitch, I'm
            Still paying back the people that helped me out all those years ago.
            Simple as this ...
            I'm a happy man that I can help
            • bigdavenorcott
              • May 2014
              • 22
              #36
              I don't suppose you can tell me how much homebrew mortar I'm likely to need for my build can you Dave? (or indeed any lurkers )
                • 2848
                #37
                G'day
                Can't tell you exactly . But I can tell you don't order in bulk.
                The sand is the most amount of material you'll need and I'd say 2 or 3 bags at the very most. Don't hire a cement mixer either you'll need small batches. A 20 ltr bucket and a large paint mixer on an electric drill will do the job for you.
                • bigdavenorcott
                  • May 2014
                  • 22
                  #38
                  Nice one. Right I'm out of excuses, better build this f**ker now
