Hi folks.
I'm building my first WFO, and would appreciate any advice that you may have.
So far, I've built a massive base out of river stones, (leaving a hollow middle with a ring around the outside), and filled the void with wine bottles and perlicrete (approx. 12-16" thick). It's a lot of vermicrete, but is less work than driving around looking for fill, and moving the heavy fill. Plus, the hearth will be extremely well insulated...
My plan is for an approx. 36" oven, 17" tall dome, made out of clay/sand mixture, 4" thick. I'm planning on catenary arches for inside and out. When fully dry, the dome will be covered with perlicrete, and finished shape will be like an old-fashioned beehive (also a catenary dome).
The oven will have an entry archway, with a flue built into the top.
So, a few questions:
1) Running the chimney straight up from the flue is not possible due to space limitations. So the plan is to have the top of the entry arch cut out, leaving an 8" hole. On top of this, an upside down flower pot with the bottom cut off (tapering from 8" to 6") From this, a flexible 6" aluminum duct running back to the middle of the oven dome and then straight up(but with as little angle as possible...) The flower pot/duct will be filled around with perlicrete, and the whole chimney will be buried in insulation. So, I know that the aluminium will degrade quickly - but will the remaining void work just as well as a chimney? I can't see any reason why not (they use a similar mix to re-line old house chimneys these days) but i thought I`d better ask here first.
2) As far as the clay mix goes, I was thinking of using (by volume) 1:1:3 powdered clay, rock dust, sand. In addition, I am planning on adding shredded rockwool fibers for more strength. Straw seems like a joke to me, for both insulation properties and for adding strength. I want strength in my thermal mass, not insulation. And I want insulation in the insulative layer, not more mass. So the dense thermal layer covered with perlicrete seems like the way to go. Has anyone done this before? How much rockwool did you use, more or less?
3) I'm a little concerned about thermal expansion of the oven walls, and them having nowhere to go if surrounded by hard perlicrete. How much does a clay oven expand, anyway? Would it be worthwhile to put on a thin layer of rockwool over the clay, then a chicken wire or fiberglass mesh, then a thin layer of perlicrete? Let that dry a bit, before adding the bulk of the perlicrete on top?
4) Do people really spend all day pounding clay into powder, and then even more time stomping on it to mix it up with sand and water? I was thinking of laying my dryed clay out on a 4ftx8ft board, covering it with another board, and driving back and forth over it. Should make some decent clay powder i believe. ( I got pure clay for free but it's wet...so i'm not starting from powder) I plan on the same technique for the actual mixing, but using heavy duty tarps instead of boards. Has any one done this before? Any tips?
5)One last thing - has anyone mixed waterglass into the clay mix from the start? I read on another forum that Red Devil TSP90 is waterglass powder, and is not very expensive. Unfortunately, I can't find it here in Switzerland.
Thanks for any advice you can give me, and for all the great info that has already helped me on this forum.
Looking forward to that first pizza!
cheers,
Jason
cheers,
Jason
