Hi all!
I'm not sure what happened to my first post on this subject, but I'm hoping that I'll have better luck this time.
I am about to mix and pour the concrete hearth slab for my Pompei style oven. I am planning to use Sakrete High Strength Concrete for the hearth slab. I believe it is a gravel-sand-portland cement mix, in a 3-2-1 ratio.
Is this the same sort of mix that everyone is using, or should I be looking for a sandier mix? If so, what are your suggestions?
