How do you determine where to end the arch and start the transition? I have around 18" from the end of the arch to the door opening, do I go 1/2 brick, full brick then start the transition, I have 3 full rows of bricks already on my dome?
I used the 63% formula to determine door opening height, I have 19" dome height and 12" door opening height, my oven is 40"W X 42"D, I noticed yesterday if I go 12.5" door opening I have a clear view all the way to the back of the oven compared to 12" height, 1/2" seems to make a big difference. Would it be OK to go 12.5" on door opening without causing any issues with venting since it will be 65% and not the recommended 63%?
