Re: Thoughts on this oven build...
Yes, I have used both. The home-brew is easier to use because it does not go off as fast as the home-brew. In hot weather I use chilled water to retard the CAC castable that I use. The home-brew has a much higher rate of shrinkage because of its high proportion of clay, so this may be a problem for you depending on your design. I have no idea about the longevity of the homebrew, but two people I advised three years ago to use it in casting a one piece dome both report successes. If you can get the CAC so cheaply then why not use it. You will still have to mix it with some kind of aggregate and that may cause problems. A proprietary castable uses high temperature aggregates (way in excess of what we need) and if the correct amount of water is added will not shrink.
Originally posted by almondsurf
View Post
