My stand is 60"x64", but I want to make the top about 4" wider and longer on each side, 3.5" thick, reinforced, poured on top of HardieBacker Cement Backerboard.
Do I need to build support for the 4" of the board that extends outside of the cement blocks? Or the board is strong enough to support the weight of the wet concrete?
I estimated that the board should support about 78lb of concrete. ( 4"x3.5"x64"x 150lb/cubic ft)
