A few questions as I consider buying a P70. Apologies if I've missed answers in existing threads, I've looked high and low and can't seem to find...
Will my P70 on the metal stand have any problem sitting on my existing patio? Existing patio has gravel base, rebar reinforced and I would guess 3-6" thick. Covered in snow right now so can't measure. Would it matter if it were centered vs. on a corner? Or moot point? I assume it wouldn't be a problem but need regardless of location but need to know if I should just pour a new slab for the oven/stand to sit on. Don't want the existing patio cracking.
How much insulation is there in the P70 dome and hearth/floor? I can't seem to find this in the forums nor in the P70 marketing collateral on FB.
I thought I read in a thread that you can't close the door while cooking and then re-open. Is this correct? But you can close when you are done? Or is the door only for closing when not in use? Confused on utility/usage of the door in general.
Does the door that comes with the P70 insulated? Should it be?
Sorry for the noob questions and thanks for the help in advance.
