Re: Starting my build
Thank you so much guys! The video helps me to see the consistency of the mix. I probably would have added more water if I had not seen that video. I will try to get it close to that 1/3 per David S.
David S: Do you think that a 2" dome is thick enough when cased? Or, does it need to be 3"+ thick?
Thanks again guys!!!
and there are lots of tools to help move things around in the chamber. The belly button height recommendation is just my opinion of the optimum height for most folks. Loading wood, moving food items (and their container pots) around the chamber, and cleaning out the ash are things I would think about when determining the hearth height. Since you're sounding comfortable with a slightly higher hearth than mine...no problems, remember your oven is uniquely yours.
instead of just sliding it. At the time I felt that I had built the hearth too low!)
--thanks for the smile
??? I did a little but didn't want to brake all the little balls of perlite, so I did a light pack and screeded it with a 2x4.
