Re: Starting my build
Those pictures are a great help. I have never heard of the elephant's foot analogy, but it makes sence. I like the idea of putting morter around edges of the pcrete, or I may wait to put some refractory cast material as a border. I may just slap it onto the side without a form as the pcrete is rough enough that it should hold / stick well to morter or cast material.
So... I have a dumb question... I have a compound miter saw with which I am planning to use to cut the firebrick like this. What type of blade do I buy to cut the brick?
Or, do I just use a hand grinder, which I have, but again, not sure which blade to use. (I assume the miter saw would be easier to make accurate cuts with.)
. I don't know the diameter of your miter saw, I borrowed a 10" wet saw (and bought a new blade) so I could cut a brick with one pass. Prices will vary, but you should be able to find a reasonably good 10" blade for between $30-$50 if you shop around. You aren't going to be making a lot of cuts for the hearth, so you don't have to go top of the line.
(As David noted, it is a little more work to use a grinder...but if you're only cutting your hearth bricks...)
