Originally posted by RandyJ
View Post
Extreme Insulation Need Advice
Re: Extreme Insulation Need Advice
awesome! I am sure you are full of knowledge and an expert by the time you have spend on the forum. So far your build looks awesome!
I wanted to start back then but between a lack of work and then a re model and then a kid. I had to wait a while to get started. I broke ground in April this year and have done everything since then. But yes I have been around her for a long time.
Randy
Oh, Sorry, I saw that you joined the forum in 2010 and started your build in 2010.... :-) My mistake. Let me know how its going buddy. I hope it comes out awesome as I am pretty sure it will.Originally posted by RandyJ View PostI am only a little farther than my pictures. Only a month and a half in to the build. But I will let you know when I am done.
Randy
Randy
Thanks Randy, I hope its enough. I looked at your build but you did not put finished pictures. Did you finish it? If so how does it perform? Are you happy with your results? Let me know buddy and thanks for checking my progress. Below is a link to my build.Originally posted by RandyJ View PostI can't wait to see what you end up doing for yor insulation. I did 4" of board and have 3 boxes of blanket and plan to back fill with vermiculite for max heat retention. Good luck.
Randy
Randy
Thanks for that David, I really appreciate it.Originally posted by DavidApp View PostHello Gugahulk
I think that the board is probable better for the door as it is denser than the blanket. The rigidity should not be an issue in the door. Mine is 22 gauge steel from a big box store pop riveted together.
I reinforced the top of my form with 2 x 6s as the vertical forms were 1 x 6s and would probable have bowed out. I should have screwed the 2 x 6 on from the outside not the inside.
My form is 2 x 6 horizontal, 1 x 6 vertical then a band of 2 x 6.
You can see the wedges on top of the blocks.
David
Hello Gugahulk
David2 Photos
Thanks David, Question, any extra being used on the Door is totally my plan. Does it work good on the door? I was thinking about either that or using the insulation board as it will not flex like the blanket. Any thoughts? Have you seen my base? I am freaking out that its not strong enough for the concrete. let me know what you think. Here is the link for my build. http://www.fornobravo.com/forum/6/wo...l-21793-4.htmlOriginally posted by DavidApp View Postany extra being used for the door.
David
I thought so but one of your last posts got me thinking it was a dome. I think you will find wrapping a barrel is easier and less wasteful than a dome. I used 2 boxes to cover a 36" dome in 3 1/2" with a little to spare.
4 boxes will be more than enough with any extra being used for the door.
David
Hello
Did I miss something along the way? Are you building a Dome or a Barrel vault oven?
David
Thanks for the input. I am guessing my self. I am planning on make it out of granite instead of tile. I have broken pieces of granite and I was planning on using it. Yours looks really nice, but there is no way I would do it that way. Its way too much work for me.
But now I am second guessing. My oven will be really FAT kind of like this one below. So not sure.
1 Photo
I think it's beautiful, but it's apparent simplicity is the result of some very hard work as each piece needs to be accurately cut to avoid lots of small infill pieces; although grout does hide a multitude of errors !Originally posted by gugahulk View PostAny thoughts on this?
As my previous picture demonstrated I haven't the discipline required to be so exact, having completed the blue/black central stripe on mine as a homage to Gaudi I got a bit carried away, hence the octopus !
Go for it; just don't underestimate the work involved.1 Photo
Thanks oblertone, But I dont mind putting the time and I love working with it. It relieve my stress from work and something I look forward to. But I dont plan on having designs on it. I am thinking more something like the image below. Any thoughts on this?Originally posted by oblertone View PostNot trying to put you off, but think very carefully before starting down the mosaic route as it can be VERY time consuming
2 PhotosLast edited by gugahulk; 06-01-2015, 09:57 AM.
