Hi Guy, My oven will be open to the elements when its all done. How ever building it now, I need some time of temporary roof over it so I don't have to cover it every single day. I bought a canopy from Home Depot and it lasted me 1 day. Look at the pictures below. Can anyone give me some type of idea on how to build an easy simple temporary solution to my problem? Thanks...
Ideas of Temporary Roof for Build?
2 PhotosBest Regards...
Gugahulk!
My Build...
http://www.fornobravo.com/forum/f6/w...-fl-21793.html
**************************************************BUILD IT AND THEY WILL COME
Food will always be the best way to spend time with family & friends, and that is all that really matters.
STOP THINKING ABOUT IT AND DO IT!
Tags: None
Re: Ideas of Temporary Roof for Build?
Do a search for "EMT Canopy fittings". You'll find stuff you can build tarp sheds out of using electrical conduit. And you just cover with standard tarps and bungee fittings
That's what I'd recommend if you need something a bit stronger. I've thought about using one of these as a winter cover in front of my oven. I did use to build an outdoor movie screen.
Originally posted by deejayoh View PostDo a search for "EMT Canopy fittings". You'll find stuff you can build tarp sheds out of using electrical conduit. And you just cover with standard tarps and bungee fittings
That's what I'd recommend if you need something a bit stronger. I've thought about using one of these as a winter cover in front of my oven. I did use to build an outdoor movie screen.Best Regards...
Gugahulk!
My Build...
