BBQ Smoker humbly requesting knowledge
  • cheapwhiskey
    • May 2015
    • 8
    Greetings!
    I am looking to build a smoker out of vermiculite concrete and I was wondering if it will be able to handle the temperatures as the primary layer and not as an insulation layer?
    Any advice would be greatly appreciated. Thank you!
    Patrick
  • Tscarborough
    • Oct 2009
    • 3341
    Re: BBQ Smoker humbly requesting knowledge
    Unless you use a ratio that will make lightweight concrete, it will be too friable to be used as an exposed surface, in which case the insulation value will be minimal (and it will begin to degrade immediately at temps over 500F.
    In short, no, that will not work.
    • cheapwhiskey
      • May 2015
      • 8
      I was going to use a 5:1 ratio, would that qualify as a lightweight concrete?
      • Tscarborough
        • Oct 2009
        • 3341
        No, and it is soft and crumbly at that ratio.
        • cheapwhiskey
          • May 2015
          • 8
          Thank you. But that is completely acceptable as an insulating layer around a steel frame?
          • Tscarborough
            • Oct 2009
            • 3341
            Yes, the best insulation value would be loose fill around a metal working surface, so long as you have an outer skin to contain it.
            • cheapwhiskey
              • May 2015
              • 8
              Skin as in a top mortar finish of some sort? I would like the top layer to be glossy . Any thoughts ?
              • Tscarborough
                • Oct 2009
                • 3341
                Here is a sequence showing how you could do it.
                • cheapwhiskey
                  • May 2015
                  • 8
                  Wow, thanks!
