With the oven stand, is there any advantage to filling every other core as opposed to just the corners? The instructions suggest either method.
I was going to just do the corners as I thought that once the hearth goes on top it would lock everything in and be heavy enough to hold the stand in place.
And with the angle iron over the opening, picture 2.5 in the instructions has it spanning the entire width of the stand and picture 2.6 has it only spanning part way across the front. Is there any advantage in either option?
Obviously the stand needs to be structurally sound but when is it prudent construction and when is it over-engineeered?
