Foundation Question
  • Archena
    • Apr 2007
    • 1214
    #16
    Re: Foundation Question
    My biggest concern is the duration of the pour itself. If I'm going to have to do it I need as short a time frame as possible simply because I physically can't last very long doing that kind of heavy labor. All the other components can be done a little along but once concrete is wet your working time is limited and you have to do it all then. You can't pour concrete in phases because it won't bond to itself - it's all or nothing. A small slab is still a lot of work - so if it has to be a slab I'll have to hire someone to do it.
    And I don't wanna hire someone - I wanna do it myself.
    Yes, I'm slightly insane - why do you ask?
    [/CENTER]
    • Les
      • Sep 2005
      • 2945
      #17
      Archena,
      If you can buy the concrete ready mixed (US Rentals) and are able to put the trailer anywhere you need to drop - it should be a slam dunk. When you screed the mud, it doesn't have to be perfect or finished. The rest of the work is just labor, you can take your time. If your forms are not perfect, you can mortar the block to get them level. In my application, I knew that I would make all things right when I got to the top of brick. The fact that my foundation and dry stacked bocks were not exact did not matter, no one will ever see it.
      Go for it - little cost, and you WILL save a lot of time.
      Hope this helps,
      Les...
      • jahysea
        • Oct 2006
        • 116
        #18
        Originally posted by Les
        Archena,
        If you can buy the concrete ready mixed (US Rentals) and are able to put the trailer anywhere you need to drop - it should be a slam dunk....
        Hi, I'd have to agree. It only took me about 20 mins to wheelbarrow all the concrete from the rented mixer to the slab. I took big loads, so allow a little more time if you can't handle a full wheelbarrow of concrete.
        The time consuming parts were finishing the slab and cleaning the mixer. Both things seem like they need to happen at once and take a while.
        If I had it to do over I'd spray a bunch of water in the mixer after filling the slab and then go spend my time trowelling the slab before worrying about the mixer.
        Note that you need a serious truck to rent the mixer I had. No small Toyota pickups or cars with hitches....
        - JC
        • ihughes
          • Apr 2007
          • 45
          #19
          I feel very lucky after reading what some people have been up to.
          After I framed my slab I phoned the local concrete company and around came a truck and backed right up to my form and poured. I leveled it off and 30 minutes later was back inside having breakfast. And it was cheaper than buying the materials and mixing the concrete myself.
          The concrete company I used has a .6cu m minimum pour which is just about right for the standard slab. Some companies for a fee can pump it to where you need it if access is a problem (of course this will cost extra).
          This is in Australia, of course, so I'm not sure what services you might have available where you're living. But I can recommend getting someone else to do the mixing.
          cheers
          Ian
          • Archena
            • Apr 2007
            • 1214
            #20
            Hi guys,
            I don't know about ready mixed - I don't even have land yet so accessibility is an unknown. I'm sure it'll be on a septic system so big trucks are likely out of the question. Worth looking into but I'd have to rent a truck as well - a Corolla ain't pulling anything heavy.
            Thing is, I've got to have enough energy left after pouring the concrete to get the rest of the job done. I dunno but I'll have a lot of time to think it over and look into the options before I have to commit to a single plan.
            Thanks!
            [/CENTER]
