Re: Help!Gas burner for brick ovens, too expensive!
:yes: They're mass produced in much higher numbers, hence the lower price,
Thank you for your comments. But do normal house ovens have all these security measures? Because a normal steel oven is even cheaper than the torch burner itself.
I'd have the plumbing put in and the gas burner installed at a later date if expense is a problem. I really wouldn't skimp on that one - like dmun said there are some pretty serious safety issues involved.
Gas burners for brick ovens are expensive for a reason, they have multiple safety features that prevent disaster. It isn't like a barbeque where any tiny gas leak will just blow away - gas can build up in the dome mixing with air, just waiting for that spark.
Wood is the way to go with brick ovens, unless you are running a high volume comercial operation, in which case you should spend the money, and most likely your insurance company will require you to do so.
Hi everyone: I'm building my brick oven but I have this problem: I was planing to buy a gas burner, to be precise, a torch burner for ovens but it is too expensive! is there another way that I can heat up my oven with gas without spending so much money??
Is there another type of burners that I can use that can cheaper?
Thanks!Tags: None
