I am in the phase of designing a door for my oven (mainly for baking bread etc.) and would like input from the great resource of FB.
The idea is something fairly simple, lower budget, single door, slides into place (rather than hinged) and a couple front facing feet (or bracket) to wedge it into place. For the door itself it could be 2 pieces (front and back) of sheet metal which are spaced apart (about 1 inch) by side pieces of sheet metal (all the way around, no gaps)....basically creating a void between the two sides. Now instead of filling the void with sand I was thinking of using some thermal blanket, once that’s stuffed into the void (say from the bottom). I could then weld the last bit of metal on to seal it in.
To seal (against the oven arch) it I could use glass fibre rope embedded in some sort of flange/angled steel (welded to door)…..still working on this past but its do-able?
Pros -
- Easy to get materials for very little or no $$$ ….for me
- I have all the tools required
- I have the insulation
- No combustible materials
Con's (questions)
-will it be too conductive, loose heat?....seeing that the whole things is all steel
- Weight....well I think I can keep it reasonable - say 1.5mm thick steel (1/16th of an inch)
- Steel will rust, so therefore I guess I need to coat it. Can I "coat" it with cooking oil like you do with cast iron pots, pans, Dutch ovens??.......Something that would be food grade rather than paint, galvanised, anodised or other hazardous coatings.
Ok…would like your feedback….. Yes it’s an idea from Russell J’s book….
Pros -
Con's (questions)
