hello.
I am new to this forum and am building an oven in my backyard in ohio. the block stand is built but before I go any further i had a few questions about which type of insulation would be best for me.
Does vermiculite expand and contract each time you use your oven?
Can you put vermiculite or perlite up against the firebrick dome with no layer of insulfrax? Can they handle the direct exposure to high heat? What happens if you do????
Is perlite ok to use in the insulating layer of the concrete hearth slab mixed with concrete???
thanks for your help in advance : P
