I know the conventional wisdom is to use perlite/vermiculite concrete or insulating board under the hearth, but I came across these Thermalite aerocrete blocks in the shop the other day: http://www.hanson.co.uk/67/blocks/th...cts/turbo.html
I should probably say straight away that I've got no affiliation with this company!
They're made from waste pulverised fuel ash, and have a thermal conductivity of 0.11 W (m.K), compared with 0.094 W (m.K) for vermiculite concrete (taken from this website http://www.william-sinclair.co.uk/in...retes?OpenPage. It seems pretty close to vermiculite concrete in insulating ability, and it'll be very easy to lay these. They're cheap too - about 65p a block (~440x210x100).
I took my blowtorch to one earlier and was able to heat a spot up to bright yellow after 10 minutes...
... and could comfortably keep my thumb about 4cm away from the heated spot once I turned the blow torch off...
The discoloration was only about 1-2mm deep - obviously the blocks wouldn't get this sort of direct heat unless my build goes badly wrong
There's some more pictures on my blog if anyone's interested.
I'm thinking about using these for my hearth insulation as they'll be so convenient and cheap. I know that there's been some discussion about using AAC blocks, but are these different? They're made of 80% ash, and I know ash is a traditional insulator for ovens. I'd be interested in hearing what people think.
There's some more pictures on my blog if anyone's interested. I'm thinking about using these for my hearth insulation as they'll be so convenient and cheap. I know that there's been some discussion about using AAC blocks, but are these different? They're made of 80% ash, and I know ash is a traditional insulator for ovens. I'd be interested in hearing what people think.
