Re: Insulation Efficiency
Phil,
2" and hopefully you have some left over to make it 3" on top of the dome will DEFINETLY be enough. You do not have to add vermiculite or vemiculite-concrete mix on top of that. I have this (mine is mostly 3"-4") with no other type of vermiculite on it. You can do the same and be fine.
Others have used the vermiculite-concrete below their oven floor, on top of the concrete base or inside the base and so they may have the stuff laying around and wanted to add more or just want to go the extra step of filling the void with vermiculite on top of everything. It will add some insulation value at relatively little cost, but I think with 2"-3" ceramic blanket, it will give you 95% of the heat retention you are looking for. -Dino
Phil,
