1" of Thermal Mass VS. 1" of Insulation
http://www.fornobravo.com/forum/f9/p...nues-2991.html -
Re: 1" of Thermal Mass VS. 1" of Insulation
I would put adding thin coating in the advisable category. Definitely nothing thick or heavy. It does not take a lot of time, or material -- and I can't think of a negative.
You will patch up any potential cracks, or spots that might leak a little hot air or smoke.
Would our experiened builders agree with that?
JamesComment
Hey James,
Thanks for the info.
I will probably add a bit to the outside, but do I really need the lime in the mix?
I hate that stuff.
I made one small batch without it, and it seemed to work fine.
I actually couldn't tell the difference.Comment
I hope our pro masons can help out, but my understanding is that lime is for workability, not heat resistance -- which comes from the fireclay.
Is that right?
JamesComment
James,
My understanding has always been that lime is used for added workability and stickiness. That's why I often use Type N with Lime (says that on the bag) when working on outdoor vertical surfaces.
Jim"Made are tools, and born are hands"--William Blake, 1757-1827Comment
The type N is very sticky stuff, CJ recommended it when I was doing my weather seal coat before tiling. As Jim says - it is great stuff for vertical surfaces, stays in place with no sagging.Comment
