Where in South Australia can I purchase refractory cement or "fondu" as I bellieve it is/was called? I want to create a vermiculite/concrete slab for the base and cover my dome with vermiculite concrete. If I can't buy refractory cement can I use Portland cement with vermiculite (perlite) and if so, will it be prone to cracking?
Refractory cement in vermiculite concrete
Re: Purchase query
Welcome, Brian.
There is no need to use refractory cement for the vermiculite concrete. Portland will do just fine for this insulating layer. It doesn't get that hot. Where you need refractories is for the mortar between your firebricks, that are directly exposed to the heat of the oven. There are several different ways of doing that: keep reading.
Re: Purchase query
Good Answer!Originally posted by dmun View PostThere are several different ways of doing that: keep reading.
And I have to agree.
Re: Refractory cement in vermiculite concrete
Hi all,
I moved this to Getting Started. Good answers.
