Well i quess im building an oven!
  • dmun
    Re: Well i quess im building an oven!
    the barrel design looks so much easier to construct
    It isn't, really, the original half-brick design is easy, as well as being strong, and light, and quick and economical to construct.
    James, the founder of FB, worked to develop a practical round oven design after building two barrel vault ovens, and being dis-satisfied with them.
    One of the reasons for all that concrete around the barrel vault oven is that the stresses that the arched roof puts on the vertical side walls. All that mass has to be heated up every time you fire the oven. This isn't a problem if you bake multiple batches of bread every day. You never loose the heat from the previous day, and you don't need the blistering heat that pizza likes. Mostly the folks who are pleased with the barrel vault design are serious bakers.
    It's also hard to sweep the ash out of the corners.
  • FIREANDFLAMES
    Originally posted by Dutchoven View Post
    Fireandflames
    Have you downloaded the FB Pompeii oven plans? If not do so, it is a great resource and really will spell out how best to tackle this project...find it at the FB store...download is free or you can be a good guy and pay a little bit to help support a great charitable cause!...either way we will certainly continue to help!
    Best
    Dutch
    Thanks for the support! I will take pics of the location today!
  • FIREANDFLAMES
    Re: Well i guess im building an oven!
    Originally posted by DrakeRemoray View Post
    Hi Lance,
    Welcome aboard!
    Why are you planning a barrel oven? Why not a Pompeii?
    Are you planning to make a high mass oven? They take longer to heat up but make loads and loads of bread.
    If you are going to cook more than bake, you will want to consider the lower mass Pompeii oven. It is much more practical for home use. Mine is still 350F 12-18 hours after removing the fire...so still a lot of mass. Sometimes the biggest problem I have is a too-hot oven. I have waited several hours for mine to cool to a proper bread baking temp (I would call mine a medium mass Pompeii, I have about 1" of additional mass on top of the fire bricks).
    Do download the Pompeii plans and let us know your thoughts!
    Drake
    Thanks for all the responces everyone, i did download the Pompeii plans as a guide and helper when i get stuck on something, but the barrel design looks so much easier to construct. That is the main reason for choosing the barrel.
  • CanuckJim
    XJ,
    I've layered a refractory insulator over as much as three inches of blanket, and compression is not a factor. Vermic/cement or Matrilite 18 simply are not heavy enough when wet to do it, and they're quite light when dry.
    Jim
  • DrakeRemoray
    Hi Lance,
    Welcome aboard!
    Drake
  • Xabia Jim
    FF, so you're 2 hours west...must be getting up in elevation. How far from Sundree? I worked west of there at 6800 feet drilling a deep hole for sour gas!
    So you guys don't see compressing the blanket as an issue? (I have not handled the stuff...is it pretty stiff?
  • gjbingham
    You get logged off while you're typing probably. Click on the "remember me?" box where you log in. You won't get logged off.
    BTW, welcome! Look forward to seeing some pics of your build.
  • dmun
    Most insulators, particularly the blanket, can be compressed enough so that you don't have to worry about the expansion of the firebrick dome.
    What's the foil for? I'm confused about the whole foil thing. I would think it's just going to make your wet perlcrete, (which is a treat to work with in the first place), just slide down and peel off your dome as you try to mound it up around the dome.
  • Dutchoven
    Fireandflames
    Best
    Dutch
  • FIREANDFLAMES
    Well then i will take some home with me. So you are saying just foil the brick then insulate with blanket so those two layers dont stick to each other when i coat it with perilite so there is some give with thermal expantion. By the way why do i get logged off automatically after like ten minutes?
  • dmun
    Wood fired ovens rarely get above 1000 degrees F (540c). Used bricks are fine for most applications.
    I don't get the foil layer at all. Aluminum foil disintegrates in contact with portland cement. Even if you found a foil that would last, why would you want it? In domestic insulation it's used as a vapor barier. Ovens get damp, and damp ovens take longer to heat up.
    I used one layer of foil between my inner (refractory) arch and my outside decorative arch, to maintain a slip plane. I knew the foil would rot out, but I mostly didn't want those two parts mortared together.
    Everything else sounds good.
  • FIREANDFLAMES
    I was walking by one of the wood burners at the mill i work at and saw a whole stack of fire brick that has not been moved for years (i can tell by the dust build up) so i checked the operating temps for the wood burners and average temp is 822 degrees C. Do you guys think i could use some of these bricks for the oven? The fire brick i am buying from a brick dealer said the ones im buying were good up to 1000C, so i could build up the back wall with the ones from work? What do you think.......
  • FIREANDFLAMES
    Hey thats a better idea i will put the blanket first! I will start my picture diary today starting with site location......! So the insulation plan is ok? Cool.
  • talisker63
    Your plan is almost identical to my barrel. But I placed the blanket on the brick and then the foil on the blanket. I wanted to keep the moisture from the vermiculite render layer off the blanket.
    The tricky part was getting the chicken wire on without too many holes getting poked in the foil.
    Oh yeah don't try and put the foil on with a windy day like I did - doh!
  • FIREANDFLAMES
    Hey i am 2 hrs west of edmonton. As for the questions it for my back yard, yes the ceramic blanket will be somewhat flattened, and chicken or diamond mesh will be used. I watched the process of the pizza oven being installed at the rest. i worked at but it was one of those four peice italy made ones and the inside looks like the refractory we have at my current job (power engineer). Well im gonna start diggin on the weekend, i cant imagine ill get very deep right now but every little bit counts!
