Help Please - about to start work!!
  • mmmhumous
    • Mar 2008
    • 106
    #31
    Re: Help Please - about to start work!!
    Finished the lintel, front arch and first course of bricks for the chimney. Also put a layer of vermicucrete (and some chicken wire) over the oven arch.
    So it's pretty much operational now (and looking like anoven) . Just need to finish the enclosure and chimney.
    I think I read somewhere (not sure it was on this forum though) that the height of the chimney is important for the draw. Is that right - or doesn't it matter?
    sigpic "Why can't you just have a BBQ like normal people?"
    • Frances
      • Aug 2007
      • 2186
      #32
      Yep, the higher the chimney the better the draw.
      Erm, and that would be because of the difference in pressure at higher altitudes...? Hot air rises and so, er...
      But you definately did read it on this forum and as far as I know it is also true
      Although some ovens have no chimney and still work, so it must be realtive.
      How much vermiculite did you put round your oven by the way? Its looking really nice - lovely archway there - but it looks a tad too slender to my mind. As it says somewhere on this forum (like just about every second thread ) you can't have too much insulation.
      • mmmhumous
        • Mar 2008
        • 106
        #33
        Cheers Frances.
        Good stuff, think I'll be adding about 50-70cm to the chimney (maybe more).
        For the insualtion, theres about 5cm of vermicucrete round the sides (I'll be adding 5cm of loose vermiculite once the enclosure walls are finished).
        There's slightly more vermicucrete on top and as well as loose vermiculite, I'm addin a roll of mineral wool insulation too (had some left over from insulating my loft).
        Basically I'm using as much insulation as I can fit in (like you said the advice given on every over thread) - Total: 5 inches below, 4 round the sides and loads on top.
        • Frances
          • Aug 2007
          • 2186
          #34
          Sounds as if you've got that bit well sorted out then.
          • mmmhumous
            • Mar 2008
            • 106
            #35
            Hopefully
            • mmmhumous
              • Mar 2008
              • 106
              #36
              Got to love wikipedia!
              Looks like it's worth me using vericucrete in the 'porch' bit oven the oven (what is that part called - under the chimney?), to try and keep the smoke hotter too.
              Chimney - Wikipedia, the free encyclopedia
              where:
              Q = chimney draught/draft flow rate, m?/s
              A = cross-sectional area of chimney, m? (assuming it has a constant cross-section)
              C = discharge coefficient (usually taken to be from 0.65 to 0.70)
              g = gravitational acceleration, 9.807 m/s?
              H = height of chimney, m
              Ti = average temperature inside the chimney, K
              Te = external air temperature, K
              • mmmhumous
                • Mar 2008
                • 106
                #37
                First pizza going in within the hour!!!!!!!!!
                Had a fire going for the last 2 1/2 hrs and been at well over 350?C (limit of my cheap oven thermometer) for the last hour and the soot has now burnt off..... yey!
                Vericucrete does make a substancial difference ~30?C less than the bits which aren't covered.
                See what everyone means about wood/fuel consumption...... and there was me thinking my wood stores were too big! ...."gonna need a bigger boat"
                Notice a slight flaw in my design. the front arch is a bit too high, so not all of the smoke is directed up the chimney...never mind, thinks I'll go for a slpit (stable style) door across the front arch which should rectify the problem. Anyway was is got hot there wasn't that much smoke any way.
                • 70chevelle
                  • Apr 2008
                  • 125
                  #38
                  mmmhumous - can you tell me the cooking floor dimension of you oven?
                  • mmmhumous
                    • Mar 2008
                    • 106
                    #39
                    Hi 70chevelle
                    Hearth was done with fire bricks and is 900mm wide and 765mm deep. The oven walls sit on top of these bricks. Thie interior dimensiona are 640mm wide and 540mm deep (up to the lintel at the front). Hope this helps.
                      #40
                      Just a little translation for us meter challenged: 25 3/16" * 21 1/4"
                      • brokencookie
                        • Oct 2007
                        • 376
                        #41
                        That calculation was just too good to resist. I made a quick spreadsheet and will post it to the tips and techniques forum.
                        • mmmhumous
                          • Mar 2008
                          • 106
                          #42
                          lol... 'tis strange how we pick and choose units - pizzas come in inches, but pizza ovens come in metric.
                          • mmmhumous
                            • Mar 2008
                            • 106
                            #43
                            brokencookie - good to know it' not just me with too much time on their hands lol! will have to try it out once I've fixed the height of the chimney.
                            • mmmhumous
                              • Mar 2008
                              • 106
                              #44
                              Few pictures of today's fire and the oven's first pizza!
                              • gjbingham
                                • Sep 2007
                                • 2021
                                #45
                                Bruce, never mind my comment on the other thread. I see what got you going. Mmmhumuos is at fault!
                                GJBingham
