MJ's Portable Oven
  • Xabia Jim
    • Dec 2006
    • 1168
    MJ's Portable Oven
    That's MichiganJim
    I want to log this oven because it's going to happen....
    Updated Design:
    a 40" Pizza oven
    Ferrocrete reinforced hearth tray/box that is 48 inches wide
    FB board and vermiculite cement under the hearth firebricks (inside the hearth box)
    Build the dome on the hearth bricks using 1/3 bricks with a thin layer of FB mix over the dome, then FB Blanket and Vermiculite cement finish with FRC stucco.
    Previous discussion was here: http://www.fornobravo.com/forum/f6/p...igns-3663.html
    MJ (aka XJ)
  • TDVT
    • Dec 2007
    • 57
    Re: MJ's Portable Oven
    Jim, I've been pondering a mobile oven for a while myself & had posted this sketch for a steel frame a week or so back for someone else interested in a portable.
    This would take the place of any masonry hearth as FB board/cal-sil would go right over this frame after it was skinned with steel. The sketch is just the heavy steel channel with lighter angle or channel to support the center of the floor.
    I think it would weigh around 450-500 lbs ready for insulation.
    Ted
