Does a pizza oven roof have to be domed
  • Ed_
    Re: Does a pizza oven roof have to be domed
    Originally posted by Dutchoven View Post
    You should check out this site http://www.earth-auroville.com/index and you will learn a tremendous amount about vaults arches and domes and why the are created in the method that they are...
    Whoops, that link is 404. Try http://www.earth-auroville.com/. It looks like the menu "vaulted structures" might be of particular interest.
  • Dutchoven
    We had someone on the forum who built his oven chamber like you speak of and it collapsed and broke his heart. He had the dome completed and it all fell inside. You should check out this site http://www.earth-auroville.com/index and you will learn a tremendous amount about vaults arches and domes and why the are created in the method that they are...it would be very wordy to try to create a posting about it
    Best
    Dutch
    Originally posted by ikhan42 View Post
    Beaglestorm,
    No i mean it would still be a dome but the bricks would step in to create the dome and the inside rather then being smooth would actually be brick steps.
    I know you guys are thinking why on earth but as I said B4 I think outside the box alot and also think this would look cool but wouldnt be any good for naan breads.
    Just a hypothetical question.
    Imran
  • ikhan42
    Hmm sounds like a good idea and if a motor is added could make a stir fry without the stirring.
    Sorry BTW havent been on for a bit things have been a little crazy son was on school holidays and I cant hide behind the pc.
    Imran
  • gjbingham
    Thread died? How about this idea - A fully round sphere oven that rotates around a fixed central plate on which the fire is built and pizza is cooked on - something like a cement mixer? The entire oven would heat equally and provide the ulitmate in radiant, infrared and convection heat to the food.
    Naaaaa...... So much for thinking outside the box!
  • gjbingham
    Sounds iffy to me. I believe the dome design seems to defy gravity because of the use of a keystone in each course of brick that locks everything together, so presumably they cannot fall inward easily. That is especially true in the upper courses as the bricks angles incline more towards vertical.
    It seems to me (and I certaily could be wrong) that locking each course of flat layed bricks with a keystone provides no resistance to inward collapse in the mid to upper courses.
    Where's dmun?
  • ikhan42
    Originally posted by beaglestorm View Post
    I think Imran meant building a dome like a hollow pyramid. Thinking about it I don?t see any way it would be self-supporting and certainly no where as strong as an arch. It sure would look cool though. Ahhhh Q-bert? what fond memories.
    Beaglestorm,
    Imran
  • beaglestorm
    I think Imran meant building a dome like a hollow pyramid. Thinking about it I don’t see any way it would be self-supporting and certainly no where as strong as an arch. It sure would look cool though. Ahhhh Q-bert… what fond memories.
  • gjbingham
    Yes, cutting the bricks in half cuts down on the price of the firebrick needed and the length of time it takes to fire the oven to pizza temps. Whole bricks would be great for a bread oven in which you intended to do multiple loads of bread.
    You lost me on the question about the soldier course and the subsequent courses stepping out. I'm having trouble what you're envisioning.
  • ikhan42
    Okay I have been thinking about the Pompei oven and have another question, is there a reason that the bricks are cut in 1/2 is this due to the sheer amount of mass that would be needed to heat the oven therefore increasing the heat up time?
    What my thought are and I am sure someone out there has probably already tried it and can give some feed back on this idea.
    If a soldier course is laid in the circular pattern and then the next course is stepped out a bit and same done through every course. What the inside of the oven will look like if a Qbert game but there would be no motar needed inside. Is there any reason why this is not a good idea?
    Has anyone tried it and can give some feed back.
    I know it means more bricks and also means more weight but doesnt it also mean a sturdier structure ?
    Regards
    Imran
  • Frances
    I think the point is that obviously other shaped ovens work, you can cook pizza in a barrel vault (or so I've heard), but the round oven works better. For Pizza certainly.
  • dmun
    We'll have to wait for James to comment on that. That's a HUGE commercial oven, and I think its more of an elongated circle than a barel vault or oval oven.
  • ikhan42
    DMUN,
    Yeah I figured it was more a from a cost perspective rather than anything else. I will be building my outer shell with bricks and then cover it with stack stone, Hopefully that will look spick.
    I have been looking at this site and am finding myself with more and more questions. From what I can gather it is recommended to use a curcular base for optimal heating with regards to pizzas. Then I see in the Casa series Pizza oven and they have one that is an oval shape rather then a circular shape, isnt the ovel shape more like a barrell rather then a circiular dome, especially with those dimesions of43.2x62.9? If it is more like a barrel then why does it get hot so quickly
    Ouch I have a head ache LOL infinite possibilites I see
    Imran
    Guys no comments re the Casa series oven and the oval shape. I havent seen one but from what the description is it sounds like a barrell rather then a dome. Anyone seen one and can comment.
    Imran
  • ikhan42
    DMUN,
    Imran
  • ikhan42
    Hagrid,
    Thanks for that I will contact them tomorrow and see if I can go there and look at the stuiff beforeI buy it.
    Talisker I have a Reece Plumbing around the corner from me I am suprised that sell Flues as they are a plumbing supplier but I will go check them out too.
    Thanks for the Help.
  • dmun
    Any non-combustible material is fine for the exterior of your enclosure, I made mine out of brick, and in fact I didn't expose the edge of my slab, it's just one expanse of brick.
    The concrete-block, wonderboard, stucco enclosure is inexpensive, thus widely used. I think a brick exterior is better, and lets you incorporate decorative arches for your entry and wood storage.
