Hey,
First post here as I have more or less just been reading through existing posts trying to plan this thing out. My goal is to create something a bit light weight in case I need to move it since I don't have a permanent home for it in the backyard just yet. My question is around the dome itself. If I constructed it with the following layers would it be sufficient to contain the heat in the oven?
First layer (starting form the inside) 2" of portland/perlite 1:5 mix
Second layer 2" ceramic blanket
Third Layer stucco to protect it from the weather as it will be stored outside through a Canadian winter.
