Setting the cooking floor
  • antwlo
    • Aug 2016
    • 14
    Hello,
    this is my first entry in the forum. I just started building my pizza oven and I have a question...
    I completed building the foundation, brick walls, and hearth. I'm at a point now where i need to start laying the firebricks on the hearth.
    I'm using Cement fiber boards for insulation.
    My question is...once I put the cement fiber boards on the hearth, do I need to put a layer of sand/fireclay on top of the fiber board before setting the firebricks or can I lay the bricks directly on the insulation boards?
    • 3884
    Antwlo,
    Welcome to the forum. Cement fiber board is not insulation.
    • antwlo
      • Aug 2016
      • 14
      thank you for the clarification. what about the need for the mixture of fireclay/sand?
        • 3884
        My insulation board was near perfectly level and even at all seams. I elected to not go with the clay and sand leveler. I only think it is necessary if the insulation layer is uneven. Is it "ceramic" fiber board that you are using for insulation? If it is "cement" fiber board, then I am afraid that you will be very disappointed in your oven's performance.
        • antwlo
          • Aug 2016
          • 14
          I'm using "ceramic" fiber board, not cement. seems fireclay/sand are only needed to ensure bricks are leveled.
          • ronfillius
            • Sep 2016
            • 1
            can you use just sand on top of the perlite insulation to lay the hearth brick, or do you need to use fire clay and sand? Also do you have to use a special food safe firebrick or is medium grade ok?
