Originally posted by Fizz
View Post
Got these firebricks, how should I build a pizza oven with them?
Bought a few new bricks for the floor and finished the part in the far end of the oven.
Started mocking up the entry arches and the flue ... input, anyone? If I use one curved brick för the flue the cross section will be 100 by 300 mm, that has to be enough, right?6 Photos
For the sake of online information searchability (!?) I think I found out what the numbers are. I bought some new floor bricks (Also Bjuf SX), and they were stamped "17 05" so I figure its the manufacturing date, year and week number. (The old ones are stamped "86 27")Originally posted by Gulf View PostFizz,
Welcome to the forum! That is an interesting shape for fire brick. A barrel vault seems to be the best choice. From the stamp in the pic I would have guessed that they were an ultrahigh 65% alumina. However, I did a quick search of those markings and found Höganäs Bjuf Refractories. A click on their products, link to a page shows a BJUF.SX (line 4) as a 35% alumina alkali resistant firebrick. So, I'm guessing that the "36.27" stamp is the actual alumina content (much easier to cut with a wet saw than 65%). From reading their page they have been in the business for a long time. You may be able to contact them with some questions. Aside from all that, clean and dry them real good so that the mortar will stick, and have fun
By the look of your pics the end walls are built beside rather than under the vault. This presents a problem when the vault expands wanting to push out the end walls. As you have also created separate arches rather than staggered joints there may also be problems there. Some steel bracing should hold it all together. Here's one solution.
Last edited by david s; 07-18-2017, 03:40 AM.Kindled with zeal and fired with passion.
Thanks for the input! I wonder how the staggered/non staggered joints affect these type of curved bricks ..Originally posted by david s View PostBy the look of your pics the end walls are built beside rather than under the vault. This presents a problem when the vault expands wanting to push out the end walls. As you have also created separate arches rather than staggered joints there may also be problems there. Some steel bracing should hold it all together.
The back wall is built under the "first arch", but the last one, before the entry arch, is only supported by half an inch "from below" by the entry arch .. I guess we´ll see what happens ...
Bought an IR thermo gun and started reading the different temps in the oven ... Most temp recommendations around the web are pretty general, and I´ve noticed that my floor temp is hard to get over 400 c ... If I fire my oven til the dome starts clearing in the "middle" of the oven, where my cooking surface is the floor is well above 400 c, but when I push the ember to the side and back and use smaller pieces of wood and "less fire" and the cooking begins, the floor cools down to 300-350 c .. As long as I´m the only one making pizzas and baking them it´s fine, the floor heats up btw pizzas, but when I do multiple pizzas in a row the floor cools down to fast ..
Any ideas?
