Will ceramic blanket compress under vermiculite layer. I see people using chicken wire to hold blanket down then adding vermiculite cement layer. I am worried that the compression of vermiculite layer, then rendering layer will compress the blanket so much it will no be a good insulator?
compression of ceramic blanket
If your budget allows, you will be happier with the heat retention if you go with more than 1" of ceramic fiber blanket plus the v or p crete.Russell
Originally posted by mellissa View PostWill ceramic blanket compress under vermiculite layer. I see people using chicken wire to hold blanket down then adding vermiculite cement layer. I am worried that the compression of vermiculite layer, then rendering layer will compress the blanket so much it will no be a good insulator?
Don't forget to scratch the first coat of render (over the vcrete) so the final coat of render can get good adhesion with it.
Are you going to have an enclosure to protect the oven from the elements? If not, you'll want to plan a waterproofing addition or acrylic coating for the render and something to keep water from seeping into the insulation along the oven/base seam.Mike Stansbury - The Traveling Loafer
Roseburg, Oregon
I agree that the vcrete is structural. It won't compress the insulation. It will support just about any amount of render. It is strongest if it is applied from the bottom up and in courses. Much like the dome brick, it will spread the weight around the dome to the hearth.1 PhotoJoe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
