Getting Started
  • 70chevelle
    • Apr 2008
    • 125
    Getting Started
    Ok - Quick update and a few questions. First, I don't have any ability to change my dimensions or plans. I'm looking at how to get the best of what I have available to me. Here goes!
    I've expanded my foundation to gain a little space, and have been working on a design that will work. I'm going to be able to get a 30" dome on my hearth. The hearth is going to be 48" wide by 51" deep. I had to do some creative engineering to get these dimensions, and have taken a few photos, and will document and post in the future. With this size hearth, I will be able to fit the 30" oven with a 6" overhang at the door and still have room at the rear for my 8" square terra-cotta flue for the fireplace. The flue for the fireplace will be built in to the hearth, open to the smoke chamber at the rear of the fireplace. The oven will also have an 8" flue at the entry way.
    Since I'm in the planning stage of the oven, while I'm starting the fireplace, I have my semi-final design.
    I plan on using 2" of FB board below my oven floor, which will be low duty fire brick set on edge.
    Question: I've seen where some have laid the walls on the cooking floor, and others have laid the walls on the hearth and left a gap for expansion and contraction. My plan would be to lay them on the cooking floor to ensure that the insulated cooking area is totally encapsulated. Good thought?
    Question: Is 2" of FB board without vermiculite/concrete below enough for insulation? By the way, I plan on using brick (solid, but not firebrick) for my hearth, not concrete, if that matters.
    Dimensions: 30" diameter, 13.5" dome height, 8.5" x 18" door opening.
    Insulation: I will cover the dome with refractory mortar, then 2"-3" of FB blanket, then fill the balance with vermiculite. The brick enclosure should allow for an additional 1" on the sides and 3"+ inches on top. All in all I'll have 2" FB Board, firebrick on edge for the floor, and 3"-6" of FB Blanket & vermiclite on top of the firebrick and refractory mortar.
    Within the confines of my dimensions and design, should I be able to cook some pizza's?
    Re: Getting Started
    Sounds good to me. The bricks-on-edge may be a little overkill. Experience has shown that brick laid flat have sufficient thermal mass.
    I'm a little concerned about the fireplace vent at the back of that 51 inch slab. Your fireplace faces forward, right? Outdoor fireplaces sometimes have draw issues without a couple of feet of horizontal run just above the firebox.
    • 70chevelle
      • Apr 2008
      • 125
      Re: Getting Started
      I think??? I have that worked out to some extent. My plan for the fireplace is to create a smoke chamber behind the firebox. The sides of the firebox are going to angle from front to back. Should look like this "\_/" if up is the front. The rear of the firebox will angle towards the front of the fireplace, from bottom to top, "/". I'm going to leave an airspace between the bottom of the hearth and the rear wall of the firebox, "|/". The hot air will hopefully rise, and end up in the smoke chamber behind the rear of the firebox, and then between the heat and the draw go up the chimney. At least that's the beginning of the plan for now.
      ps - per my current design the center of the chimney will be approx 44" from the front of the fireplace.
      • gjbingham
        • Sep 2007
        • 2021
        Re: Getting Started
        I love the idea of the firebricks laid on their sides for the oven floor. Considering that a lot of people have difficulties maintaining a hot floor, I think the extra mass is nice insurance will not greatly increase your fuel consumption compared to flat laid bricks.
        GJBingham
        • wlively
          • May 2005
          • 384
          Re: Getting Started
          If you are going to mostly pizza, I would agree with DMUN and go with bricks lying flat. My thermocouples show the floor is the slowest to heat up and lying them sideways may increase your firing time more than a little.
          Anyone with side floor bricks have any experience to report?
          Wade Lively
          • asudavew
            • Jul 2007
            • 1880
            Re: Getting Started
            I would agree.
            It's hard enough getting heat to saturate the floor when the bricks are laid flat.
            My thread:
            My costs:
            My pics:
            • 70chevelle
              • Apr 2008
              • 125
              Re: Getting Started
              The amount of information makes my head spin. I'll tell you what I've read on here and other forums. Thinner floor will heat quicker, but cool faster. Thicker floor will take longer to heat, but retain the heat longer. For pizza's, it seems that the floor temp is very important, especially at higher temps (800+) and you don't want your floor temp coming down as your cooking. So which one is more efficient? Would you use more fuel for the longer heat up, and then longer cool down, or more fuel to keep your temps where you want them while you're cooking? Anyone?
                Re: Getting Started
                As a historical note: Pompeii oven building arose from frustration with the massive Scott style barrel vault ovens. When I joined the forum in the summer of 2005, the style was to put the vermiculite layer under the support slab. This didn't heat up at all well. Then there was a brief period of putting a second layer of brick under the floor, or just a slug of concrete there, buried in the insulation. This was called the island hearth. At least this left the floor insulated, but it still too too long to heat up. Finally, the idea of extra mass under the floor was abandoned, and makers (myself included) just put a single layer of flat bricks directly on the insulation.
                The way to keep the floor hot is to keep a fire with flame licking up the dome of the oven. The produces a lot of heat, and it recharges the floor between pizzas. Commercial ovens have thicker floors (and thicker domes) but they use bigger fires, and they never fully cool down.
                • james
                  Brick Oven Merchant
                  • Mar 2005
                  • 4648
                  Re: Getting Started
                  Originally posted by dmun
                  .... Commercial ovens have thicker floors (and thicker domes) but they use bigger fires, and they never fully cool down.
                  I could add one thing. Commercial ovens are thicker, but not a lot thicker. If a residential pre-made oven is about 2 1/2-3", and a Pompeii Oven using half firebricks if 4"-4 1/2" thick, a professionally made commercial pizza oven is about 4"-5" in the dome and 4" on the floor.
                  • wlively
                    • May 2005
                    • 384
                    Re: Getting Started
                    I would not change my flat floor. I have cooked 10 pizzas without issue or much additional wood. For my usual family bakes, once the dome is white, I simply push the fire to the back of the oven and that is fine for at least 5-6. We are talking large 16" pizzas here. If I am doing more I add a 3-4" dia log or two after pushing the fire back. I have never had to add any more than that.
                    Wade Lively
                    • 70chevelle
                      • Apr 2008
                      • 125
                      Re: Getting Started
                      I still have time for the final decision of flat or on their sides. Tonite I should have the foundation completed and ready for layout of the firebox and brickwork. Once that's layed up, I'll have to make a decision. I had another question, as I tossed and turned all nite thinking about this. Should I be using refractory mortar for the firebox bricks?
                      Also, I plan on laying bricks for my hearth and was thinking I may want to use some FB Board on below (the ceiling of the fireplace) to protect those bricks/mortar from the heat of the fire. Would this be overkill?
                      • PeterW
                        • Jul 2007
                        • 66
                        Re: Getting Started
                        Ok -
                        Hi
                        Your dimensions are similar to mine, but I've got 4" of AAC under the hearth, and then a further 3" of vermiculite concrete. Not sure if this is overkill, but I've always worked with the premise that you can never have too much insulation...!
                        I've gone for the dome on hearth approach, as there is less cutting of hearth bricks in curves, which has to be easier !
                        Nice to see someone else with a 'smaller' oven !
                        Peter
                        • 70chevelle
                          • Apr 2008
                          • 125
                          Re: Getting Started
                          Peter - it's pretty funny that I was counting the bricks in your picture from the AAC thread this morning. I came up with about a 24" interior diameter? I planned on posting a q on that thread but you saved me the trouble. Looks good.
                          • gjbingham
                            • Sep 2007
                            • 2021
                            Re: Getting Started
                            Re: refractory mortar for the firebox. I believe that is what the intended purpose of heatstop mortars are for. My answer is yes.
                            GJBingham
                            • SpringJim
                              • Apr 2008
                              • 562
                              Re: Getting Started
                              I still have time for the final decision ...... I had another question, as I tossed and turned all nite thinking about this.
                              Welcome to the club.....ain't it a blast
