Excited to be building my first WFO! My plan with the base pictured is to lay 2" granite or bluestone slabs (stair treads, capstones etc) across the concrete pillars to be used as the weight-bearing load and overall base for the oven floor. I have insulating CalSil board to place on top of the slabs, and was planning on putting 2" firebrick on top of the CalSil board. Does anyone see any structural problems with using granite or bluestone (i.e. they might not be able to support the weight of the oven or may crack under the heat)?? Also, do I need more thermal mass between the firebrick and CalSil board? Thanks for any input!!
PS: the length between each of the 4 stands is approx 18" each.
