Can you review my 42 inch oven design please
Wow that is a serious oven!
You have built a huge entrance, that will be a large piece of mass to heat up, did you insulate between the main oven and the entrance?
What are the floor slabs made from?
did you insulate around the chimney pipe?
what type of insulation have you used on the outside of the oven?Comment
Fox I used a 80mm+ layer of vermicrete and 2 layers of calcium board under the entire oven. I also used the calcium board as insulation between the oven arch and flue arch as a thermal break. Yes I wrapped the flue in insulation I also poured the flue support/arch buttress out of vermicrete. It’s a 42inch oven. The insulation on the outside is a fyrewrap made as is good for over 610 degrees c. It’s made with insulfrax which is calci, magnesia and silica. So mineral fibre. I did 2 layers. I will cover with vermicrete and render.2 PhotosComment
The 1st slab is suspended concrete 32mpa 180mm thick sitting on bond deck supported by blockwork with 12mm and 16mm reinforcement. I then scrabbles the surface where the pizza oven sits and poured a 15mm high strength bed 70mpa and waterproofed this. That bed will keep the oven away from any moisture wicking in from the structural slab. I then topped that with 80 to 100mm of vermicrete. Then 2 x 30mm thick calcium silicate boards. I cut my fire brick tile 300x300 x 50mm to sit on that to the internal floor space of the oven. I ran a sailor course to support the dome directly on the board also. I’m hoping I’ve insulated well enough so the dome area heats up quick and holds heat for a long time. Going to build a door out of some left over calcium silicate board I’m thinking.Comment
