Fireclay and sand below the floor
  • andrewe
    • Aug 2018
    • 16
    Hi, I'm about to finish up the oven floor. Do I need to put sand and fireclay under the bricks or is this just a measure to create a level surface? Below the floor I have a layer of vermiculite concrete and then below that is the slab of concrete.
    Thanks!
  • Les
    • Sep 2005
    • 2945
    It's used to get the floor even. If your surface is level and the bricks uniform thickness - it can be omitted. I used it but ended up using a belt sander to get the surface flush.
    • Chach
      • Mar 2018
      • 635
      That Fireclay sand mix is some sticky stuff. Works very well if you need to use it
      My Build Pictures
