Which Chimney pipe do I need?
  • Brwilliams88
    • Mar 2019
    • 13
    Well the time in coming where I need to start thinking about how I am gonna build my chimney and I have a few questions. My oven is going to be in an enclosure(dog house) and I am planning on making my chimney with the metal studs,cement board finished with a veneer stone and this will go all the way to the top of the pipe so no pipe will be seen, just the rain cover. so my questions are;
    First, What is the difference between Double Wall Chimney Pipe and Double Wall Stove Pipe and if there is a difference which one do i need ?
    next is, I dont plan on having that pipe being visible so i black pipe good to use? just dont want to spend alot of money on some nice stainless steel pipe if its never going to be seen.
    last is what is a good site to get this stuff from ?
    thanks in advanced
    • 9213
    A stainless pipe doesn’t stay nice and shiny anyway, it goes a kind of pewter colour. But if you are covering over it that’s irrelevant. It needs to be stainless, an ordinary pipe will need to be replaced in a few years so stainless single wall is what you need.
    • Brwilliams88
      • Mar 2019
      • 13
      Thought people were saying to stay away from the single wall?
        • 9213
        Only stay away from it because it can get hot to touch. Or if it penetrates a roof it needs a double flue so your house doesn’t burn down. As you are building around it that becomes your outer skin.
