G'day All,
If anyone has thoughts/recommendations/experience good/bad in relation to the following please let me know.
Building the base now and designing the structural/insulation layers. I'm somewhat limited as I have about 6 and 3/4 inch thickness to work with for structural and insulation layers. It's been difficult to determine if the fibre or silicate boards are suitable to have the dome and floor bricks laid directly on them. I cant really sink the board into the structural layer and cover with high temp mortar as that would reduce the structural layer thickness too much. Bottom line is I intend to use a little under 4 inch of structural concrete and a little over 3 inch of perlite on top of that and lay the oven dome and floor directly on the perlite. I have 2 relatives that very very successfully cook loads of pizza's in their ovens and they don't even have an insulation layer.
Any advice welcomed, have you used perlite?
Kind Regards
Kind Regards
