Hi All,
I am new here and I have been reading a lot of posts the last 2 weeks. I am living in Thailand and I want to build a pizza oven that will last a long time. I will build it under a roof so during rainy season it will be dry however the climate here is tropical so a lot of sun, heat and very high humidity.
I used the build one before (6 or 7 years ago) using refractory cement but that one did not last long... the cement did not adhere to the bricks, cement did crack and it was still soft after weeks so when you touched it, it went back to dust... maybe that type of cement should have dried under a high temperature??
I will be using fire bricks and there is only 1 size available here which is 6.4 x 11.5 x 22 cm.
Most of you use the home brew with Portland but it is very easy here to get really all kinds of refractory materials (castable, insulation materials, refractory plastics, mortar, etc) but I have no idea after reading the last couple of weeks what I should use.... Should I do a home brew or use refractory?
The Portland home brew seems more difficult here because most of the people here are not technical enough and have for example no idea what Powder Clay / Fire Clay is or Hydrated lime (Calcium Hydroxide). Even the sales people of the refractory company could not give good complete answers to the questions I had. I understand some of you go for the cheaper solution but the price for me is not that important... It is more about the materials I have access too.
I want a dome that I can use for a long time in the climate (tropical humidity) where I am....
I need some advise please, below some specifications and the question is what is the best option (or should I go for the Portland mix).....
Type 30AM (Air Setting)
This is a wet type and a pre-mix version that is ready to use.
Silica 55%
Alumina 37%
Iron Oxide 1.8%
This is not 100% in total but that is all the info I got from the manufacturer....
Orton Cone: 30
Modulus of rupture after drying at 110 C - kg/cm2: 25
Type 30AMD (Air Setting)
This is the dry type of the above and I need to add water myself (and maybe other things?)
Silica 45%
Alumina 43%
Iron Oxide 2%
Orton Cone: 28-29
Modulus of rupture after drying at 110 C - kg/cm2: 20
The company does advise that the joints between bricks should be 2 mm which is almost impossible to make when I need to cut the bricks in shape. Would there be any problem making the joints bigger (example 1 or 1.5 cm?)
I worry because of the joint size they advise and.... would it dry and adhere to the bricks without heating up the oven above 500 or 600 degrees? or will it adhere even without any heat?
Hope to get some help of you!
Sven
Silica 55%
Alumina 37%
Iron Oxide 1.8%
Orton Cone: 30
Silica 45%
Alumina 43%
Iron Oxide 2%
Orton Cone: 28-29
Sven
