Hi everyone, first post here after lurking the forums. Hope I can have some insight here to my question:
I am making my own diy oven, similar to those you see molded by a yoga ball. That brings my internal oven diameter to only 28 inches. I'm not finding any recommended proportions/measurements for such a small size so my question is: for my oven size, can you recommend for me the appropriate chimney diameter and appropriate opening size that would be best for thermals in my build?
Here's my current setup so far.
Thanks for reading.
PS. The reason I am going with this small size is because I simply can't find any other mold that would render a larger diameter right now. So my plan is to make this small oven all good and well (and some learning) and use it in the future to mold an even bigger one. Thoughts?
Thanks for reading.
