Evening all.
like a lot, I’ve been reading and following for long time and have recently actually sighed up in anticipation of actually starting my own build.
ill be starting a build thread in the next day or 2 but I just wanted to put a few questions to the forum first.
I’m fairly limited with size. I have room for a external dome size of 1200mm and I want the outside of the oven faced in brickwork rather than render so this automatically sucks up a lot of dome space.
im proposing a 110mm internal fire brick, 50mm insulation blanket and then a I plan on cutting headers down to 75mm for the outside. So a wall thickness of 235mm X2 = 470mm. This will give an internal dome size of around 700mm
what’s everyone’s thoughts on this and I can I get away with 2” of insulation?
our neighbour has a prefab pizza oven with a 600 internal diameter and it easily deals with parties of 15+ people and for this reason I think 700 will be fine. I know bigger is better but I don’t have the room.
Look forward to the replies.
thanks.
ian
thanks.
ian
