question about floor
  • Adrianvip
    • Jul 2020
    • 5
    HI Guys.
    so I build a 6x6 base from ciment blocks sitting on a concrete slab then i put a top concreate slab reinforce with ribar and 6000 psi concreate.
    now I want to put a 5x4 x 3.5 inch thick slab made of 1 to 5 cement make and perlite. The dome will be made of 9.5x4.5 fire bricks.
    I was wondering if the cement and perlite will hold the dome or should I sit the dome on the concrete slab?
    • 5262
    Dome on pcrete,if you place on concrete, heat will transfer down through concrete hearth which acts as a heat sink. Need to make sure the it was 5 parts perlite to 1 cement not the other way around otherwise the pcrete does not offer any insulation value. and 5 to 1 is strong enough to support the dome. If you have not downloaded, reviewed and study the eplans from Forno Bravo I suggest you do before you go farther. Answer to most all questions can be found there or in post in the forum. Click image for larger version
Name:	Vcrete K values.JPG
    • Adrianvip
      • Jul 2020
      • 5
      Thank you. I will. I just boughtp 7 bags of perlite medium soil mix.
      is there any difference between perlite and perlite soil mix or is just wording.
      • Dr. Leslie
        • Jul 2020
        • 27
        Deleted as I have a reply on another board. Thanks
