I am planning on using regular red brick, due to the difficulty of acquiring firebrick. I am starting to get the plan down pat, but I still have a few concerns.
If I lay the bricks on the right angle and fill the gaps with mortar, then the only issue I foresee is that there's less thermal mass overall due to more gaps. Is this a big concern?
What other considerations to this approach have I not taken into account?
Also, if I'm doing it this way, do I need to leave a mortar gap on the inside? or can I just fill up the V gap on the outside?
I'm not looking at cutting bricks into a taper, as that's too onerous for what I'm trying to do, even though I've seen a lot of recommendations of doing it this way. If it's highly preferred, I'll look to source tapered fire brick
