Type of Medium Duty Brick
  • McGooster
    • Jun 2020
    • 31
    Hi everyone,
    I recently reached out to my local refractory and asked for a Medium Duty Brick that had Alumina - 38%, Silica - 50%, Density - 138 lb/cu/ft and a Service Temperature - 2450 F.
    When the refractory reached back out they mentioned they had a firebrick branded as 'Ovenzz' meant for fire ovens but had the following: Alumina - 43%, Silica - 52%, Density - 142 lb/ft3
    I just wanted to make sure that those specifications would still work for a pizza oven or if I should look elsewhere to find more exact for a medium duty brick?
    • 5262
    Ovenzz is a NSF rated brick promoted by Harbison Walker, supposedly touted as food grade. Should work fine, it may be more expensive than a non branded refractory brick which is typically used WFOs on the forum. You will just need to evaluate cost comparisons and benefit trade offs (if any).
    • McGooster
      • Jun 2020
      • 31
      Ok thanks Russell. Ill see if there are any other options in the area to compare too. Good to know this will work in the event I go this route.
