Started the Process - A couple of Questions
  • #16
    Re: Started the Process - A couple of Questions
    With the seven inch saw it's either cut-and-break, or flip and cut twice. A 10 inch saw makes life easier, no doubt, especially when it gets to any fancy fitting. I have both, (and a 4.5" cheap angle grinder) and I never touch the 7" saw anymore.
    Again - the table saw like model throws stuff up in your face. Most disagreeable.
    The roughness of the vermiculite layer was the original reason for a slurry (now used as a dry powder layer) of fireclay and sand under the floor: You can get the floor bricks to lay flat.
    • #17
      You guys are amazing. Thanks for the insights. If I use the board I dont use the vermiculite/portland mix right?
      PS. do you guys ever sleep?
      Thanks,
      GT
      For all pictures of oven build click address.http://picasaweb.google.com/ghtaylo/GeorgeTSPizzaOven
      • #18
        Never!!!!!!!!
        • #19
          Originally posted by DrakeRemoray View Post
          I used a 7" saw it can be done...If I had to do it again I would get the 10"...makes life much easier.
          I agree with Drake. I used a small saw too.
          The mixture wasn't bad to work with at all.
          But I topped mine with about a 1/2 inch of high heat mortar.
          Here's a picture. You can see the layer on top.
          My thread:
          My costs:
          My pics:
          • #20
            Got the stand finished. And a start on the fireplace structure.....all for today. This afternoon and tomorrow hope to pour the hearth. If I am going to use the FB board, no vermiculite.....correct?
            Pictures.
            Picasa Web Albums - George - George T's Pi...
            Thanks,
            GT
            • #21
              George, perhaps someone else can tell you exactly how much insulation is enough, such as if you use FB board do you still need vermiculite. All I know is that you can't have too much insulation. If you budgeted for FB board, I'd say use both. I used both, a 3-1/2 inches of perlcrete, and then the 2-inch insulation board resting on top of the perlcrete.
              "Pizza, the world's most perfect food."
              • #22
                I bought my material for the hearth. Both the insulating hearth and the structural. Can these both be poured the same day? Do I pour both the same size? The instructions say you can pour the insulating hearth smaller....how much smaller? Sorry for all the dumb questions?
                Thanks,
                GT
                • #23
                  There are no dumb questions. I poured the structural layer, and waited a few days to pour the insulating layer of portland/perlite. I actually poured both slabs the same size, but I think it is better to make the insulating slab smaller, because it is so crumbly. I think it should be be big enough so that your oven fits within it (Hope that makes sence). Check out the Badger build photos, he did it correctly.
