first post - so bear with me if this is in the incorrect location for this question. In a little bit I will post a longer description of "me" in the Introductions forum.
First Question: I am looking at building an oven around the Forno Bravo Permio 40" rafractory dome. The kit comes with ceramic blanket (4") to insulate the dome. The sales people at Forno Bravo state that that blanket insulation (with appropriate stucco on the outside of it) is all that is needed. However, for a number of reasons I am for now planning on building an enclosure and roof around the dome (appearance and weather protection. Also, as part of this "adventure" (wished for for decades, only now really a possibility), I am highly, highly, highly interested in using retained heat to do lower temp cooking activities (both because of "what" I want to do, as well as to be more efficient with time and fuel.
So here is the question: If I have this free air gap between the finished dome and the outer enclosure, what are the implications of filling this "dead space" with loose vermiculite (not vermiculite concrete)?
1) is doing so likely to significantly increase the heat retention, and extend the available retained heat cooking time (in other words, is it worth it, or is the gain in behavior minimal and not really worth it)???
2) Is doing to just asking for problems: like moisture accumulation and mold growth , lack of access to the dome for potential repair, and moisture induced damage to the dome and inner wall of the enclosure?
I have seen a number of postings about filling this space with loose vermiculite, but no serious discussion of problems might be created by doing so....
I have a few other questions as I seriously evaluate doing this build, but lets start with this one....
Thank you in advance for your experience and insights.
