water-logged insulfrax
  • e15757
    • Sep 2007
    • 9
    I started my dome and before finished we went through some of those midwestern rain storms. In the meantime I had my insulfrax down with floor and walls started. The big winds blew my tarp off and the thing caught a ton of rain. The insulfrax is totally water logged. I guess once fired the insulation will dry...anyone know if there are any adverse affects to the insulating properties?
  • Wiley
    • Mar 2008
    • 804
    Re: water-logged insulfrax
    Not a problem, in fact the glass blowers I know usually wet Frax before working with it to keep the problem of hazardous airborne particles to a minimum. It does take some time to dry and they do not soak it completely, which I guess yours has been. Have you tied blotting it carefully with terry bath type towels?
    Wiley
    • jpar
      • Oct 2007
      • 29
      Tensile strength of the blanket may be affected - It might tear easier, but insulation characteristics should not change - Let it dry out in the sun. Insulfrax is a much healthier alternative then standard ceramic fiber, but does not have quite as much tensile strength.
      • e15757
        • Sep 2007
        • 9
        I'm sorry for the terminology my mistake. I'm referring to the insulation board that is under the dome..I guess it is fiberfrax duraboard. It sopped up water like a sponge...and the dome is already built on top of it. Luckily my blanket is still dry :-)
        • james
          Brick Oven Merchant
          • Mar 2005
          • 4648
          It should just dry and retain it's strength and shape. I left my insulation out in the rain (blanket and board) just to see what would happen, and it dried out without problem. Our ovens do not stress the insulating capabilities of these ceramic products.
          Pizza Ovens
          Outdoor Fireplaces
