Uneven Patio
  • David247
    • Jun 2022
    • 2
    Uneven Patio
    I have a large existing patio that slopes away from the house. It is 30'x40' and it has been there for roughly 8 years. It has 4 inches of concrete with steel over a 6" base of compacted crushed limestone so it is good and solid. I will be installing a fully assembled Vesuvio 90 on a concrete block base with a 3.5" thick re-enforced concrete countertop. Along the side of the block base, the patio drops roughly 1.5 inches.
    I think that if I just dry-stack block on the existing concrete and then level the counter top, it will be quite noticeable when looking at from the side. But if I use mortar and level the lower course and dry stack the rest, it would look better and probably be more stable. Has anyone had to deal with this? Does anyone know the pro's and con's of doing either, or is there a better solution that I am not thinking of? Thank you
  • LiudwigXIX
    • Aug 2020
    • 3
    I tackled a similar project last summer with a sloping patio. I used mortar for the lower course of the block base to get everything level, and then dry-stacked the rest. It really helped with stability and looked much cleaner. The mortar made it easier to ensure everything was level from the start. If you’re looking for tips or supplies, you might find some useful options on this .They’ve got some great materials that could be handy for this kind of project.
    Last edited by UtahBeehiver; 08-22-2024, 11:51 AM. Reason: Removed commercial link
    • libertyhillmichael
      • Mar 2024
      • 96
      Having patio slope is pretty common so to have proper water runoff. Another option which I did is to dry stack and then make up the difference in the concrete counter top to be level. Good luck with your project!
      libertyhillmichael
