How Many Bricks are needed?
  • SpringJim
    • Apr 2008
    • 562
    This question get's asked a lot and could be a sticky!
    How many firebricks did you use for your oven?? Maybe builders could post your oven size, a description and the number of bricks you used.
    The plans called for 180 or 200 for the 36 and 42 inch oven floor and dome......but Actual mileage varies with individual technique (taper cut or straight?) some may use more firebricks bricks for the entry arch and vent area.
    Other thoughts?
    Sharing life's positives and loving the slow food lane
  • Ken524
    • May 2007
    • 1655
    Re: How Many Bricks are needed?
    My oven:
    42" Pompeii, all bricks custom cut (tapered on three sides): 290 bricks
    Ken H. - Kentucky
    42" Pompeii
    • rlf5
      • Jul 2007
      • 322
      Originally posted by Ken524
      My oven:
      Yea I believe I used about the same...a lil less actually since I casted my dome cap. If you don't taper, I think you can get away with less.
      Oven Progress
      Bread Photos
      Oven Stand Thread
      • Les
        • Sep 2005
        • 2945
        275 here (and a pile of scrap)
        Les...
        • asudavew
          • Jul 2007
          • 1880
          42" Pompeii
          I did no tapering.
          But I did cut the floor.
          Floor --------------50 bricks
          Dome ------------140 bricks
          Arch and entry ----27 bricks
          Total ------------217 bricks
          Dave
          My thread:
          My costs:
          My pics:
          • RTflorida
            • Jan 2007
            • 1446
            36", cut to fit...211 total (if I actually started with the 215 I picked up - I never actually counted each one, I took the brickyards word). Had 4 left over.
            RT
            • SpringJim
              • Apr 2008
              • 562
              Les...
              for the record, I've been using the scrap cuts on the mortar joints between the bricks.....kind of like brickcrete....I thinks it will give me stronger joints.
              • karl
                • Jul 2008
                • 122
                Hello there,
                I am starting up my own 36" Pompeii oven project. Is it correct to assume that your brick count are half-bricks (2 1/2"x4 1/2"x 9" cut in two)? I will need to do the cutting myself and fix the approximate number of full length bricks.
                regards from karl
                • rlf5
                  • Jul 2007
                  • 322
                  Originally posted by karl
                  Hello there,
                  regards from karl
                  Unfortunately not. They are full brick numbers.
                  Oven Progress
                  Bread Photos
                  Oven Stand Thread
                  • karl
                    • Jul 2008
                    • 122
                    I see,
                    The Forno Bravo materials list specify 120 bricks for the dome, 60 for the floor and then 30 common clay bricks for the vent and opening arch. I guess I will order some 190 fire bricks.
                    Thanks.
                    regards from karl
                    • Ken524
                      • May 2007
                      • 1655
                      Yep... Full brick numbers.
                      It really stunned me when karl asked if those were half brick numbers. I just realized my oven has over 580 (half) bricks in it. Yikes!!
                      Ken H. - Kentucky
                      42" Pompeii
