Re: Building a Pompeii Oven - finally
Today: Saturday 07/19/2008: I built the hearth support and assembled the frame, but I still need minor adjustments for the frame to fit right. I could not continue working, the rain came in.
I will try tomorrow.
Eddie
my pics:
My Brick Pizza Oven
Hello woodhead (sorry; you did not leave a name)
I found the fire bricks at Jinkins Brick Factory, they are at Phillips highway, at the corner of JTB. they also have the fireclay by the bag. The firebricks are $1.15 each. I found the Vermiculite at Halls Ace Hardware, they are at San Jose Blvd, at the corner of Loretto, they have the 4CU ft bags for $16.00.
Everything else that I needed I found at Lowes. You will not find the high heat mortar You will have to follow the formula provided within this forum, Lowes has all the ingredients. Send me an email provided in my profile, and we will arrange to meet.
Looking forward to hear from you
Eddie
my pics:
My Brick Pizza Oven
Eddie,
Congrats on your progress, i too have been prograstinating the oven build. I live in Jax beach and would love to find out where you are procuring your fire brick and other technical products needed for the build. Also, wouldnt mind visiting the build as well! Good luck and look forward to hearing from you.
I completed pouring the concrete in the cores today, next step is the hearth. Hopefully on the 19th.
piu tardi
Eddie
my pics:
My Brick Pizza Oven
This is exactly what I was looking for, Thanks Dave
piu tardi
Eddie
63 is your width side to side.. so the center of your slab should be the center of your dome.
31.5 inches from either side.
Now measure from the center of the back to 31.5 inches.
that will keep the same distance around the sides and the back.
18" + 4.5" + 1/2" + 1" + 4" = 28"
floor / brick / cladding / blanket / vermcrete Total 3.5 inches left
(... Enough room that you could build an enclosure....)
70" - 31.5" = 38.50" left over for the front.
18" + 4.5" + 4.5 " + 4.5" + 4.5" = 36"
floor / brick / inner entry / vent hole / outer entry
Looks like you will have 2.5 inches to spare up front....
I hope this makes sense.
DaveLast edited by asudavew; 07-10-2008, 12:42 PM.
Yep you are right, but that is from the sides, I was trying to figure out the distance from the back of the stand.
Thx
piu tardi
Eddie
Don't forget that you have the brick, insulation and blanket depth on both sides of the oven so:
36 +
(4.5+1+ 4) x 2 = 19
55 inches total...
Plus the enclosure...
Thanks Elizabeth,
I am no math major either, but : 36 + 4.5 + 1 + 4(vermiculate;i.e.insulation) = 45.5 and let's say 2 inch stucco or concrete board, that is 47.5, the plan on page 13 refers to another 5" insulation, is that in addition to the 4" vermiculite?
piu tardi
Eddie
Your 36 is the inside dimension. Add to that your half brick depth (4.5), your blanket (1 inch or more, depends on you) and how much vermicrete you need (4 inches, usually) plus your finish (stucco or framing). If you're using 1 in. blanket and 4 in. vermicrete, plus stucco, you'll need at least 57 inches diameter on center. Or, framing the answer the way you asked it, it needs to be at least 10 inches in from the back, using those materials. You'll need a little more if you're framing it in to accomodate the metal studs.
Please check my math, as I am the queen of stupid math errors...
How far from the back should I start my dome?
I have a question: how far from the back should i start the dome? I look at page 13 of the plans, and I am confused, I am building a 36 " Tuscan oven, and i will center the dome left and right, and I know about the oven and vent landing. But the chart on page 13 says oven depth interior 36, exterior 45, and then there is 5 " insulation which i thought was part of the 45, am I mistaken?, my stand size is exactly like the plan 63X70.
thx
piu tardi
Eddie
Thanks Christo,
Yes , I had to use the axe too.
I am only home every other weekend, so I am going to try and pour the hearth & the insulation on Saturday the 19th.
I looked at your progress, you are very brave my friend. good work.
I also have a project car sitting in my garage, but it is complete now;1989 red IROC-Z with an LT4 engine (of course it does not look like a 1989 anymore).
piu tardi
Eddie
Nice site - please post pics here too if you like - we love them!!
I located my oven around some large trees I cut down to make room for the outdoor kitchen. I still had a lot of large roots to contend with - mostly Axe work but used the chainsaw on a few- almost instant dulling of the chain but there was no way to get through some of those with my axe...
What a great start! You're well on your way!
Christo
Thanks Christo,
Will do. I will be able to share my website soon.
piu tardi
Eddie
