I'm not sure if it's too technical a question, but I can't seem to get an answer, so I'll try again.
1) Is it a problem to put the FB Blanket on top of Vermicrete? It would make for an easier install if I filled few voids with vermicrete and then applied the FB Blanket. I have the vent complete and the exterior arch complete, but no pic. The area I'm looking to add the vermicrete is at the lower arch, instead of forming the blanket to the way that it is in the picture.
2) If you had to choose between the 2 (as I do), would you:
a) Cover entire structure with 1" FB Blanket and then 3"-4" of vermicrete; or
b) Pour the side walls & rear wall (barrel vault) with 4" of vermicrete and use 3" of FB Blanket on the dome only.
If you can imagine from the pic below: the brick is going to continue up to the where the dome starts. The area between the oven wall and the exterior wall is going to be filled one of the 2 ways above. My initial thoughts are to go with b), but am looking for other views. By the way, my budget is at $0 so buying a couple more blankets is out of the question, so I'm really looking for the best option from above
