Insulation boards not flat...
  • Insulation boards not flat...
    Hi All,
    After working hard to get my hearth slab flat, I find that some of my insulation boards are a bit warped, or curved...essentially not flat. My plan was to lay down the boards on my slab, put on a layer of firebrick, and install the oven on top. Not having that insulation base flat tends to complicate matters.
    Has anyone ever tried to flatten out a ceramic fiber board, perhaps by weighing it down on a flat surface (like my slab), or should I return the boards and get a replacement?
    To give you an idea, if I lay the worst board on my slab, I get a 1/2" gap between the slab and board.
    Thank you all for any advice you can provide.
    PF
    Re: Insulation boards not flat...
    PF
    Yo Freak (always wanted to say that, kinda like, Hi Jack in an airport)
    What happens if you start loading them with the weight of the brick? If thats not the solution, could you trim the high spots off and level it with fire clay? My boards were pretty true - you have a strange situation - who made the product?
    Les...
      My thoughts are along the lines of Les. Although I have not used the insulation board, from what I've read I would think it to be light weight and have a bit of flex over the length of the board - which the weight of the bricks should should counter....again, I have not used, so I don't know; but it wouldn't hurt to lay out the board and start laying on the hearth bricks and see what happens.
      RT
        Thanks guys for the reply...
        Well, I've decided to try to stack my boards, top with a piece of plywood, and weigh them down with some cement pavers I have on hand (on a flat surface, of course). The board is somewhat resistant to bending, but obviously it was flat to start with and has been deflected in transit, so it must be able to "deform" back into place.
        Would it help to wet the boards?
        I'm surprised that more people don't have this problem, but I'm a neophyte here.
        Thanks for the input!
        The Freak
          What product are you using? Un-flat boards are not someone has reported here before, and quite a few products have been tried.
            Hi dmun,
            I was hoping that I could find people out there who've dealt with the same situation (if it is common)...and have corrected it. Again, I'm not sure how common this is and how correctable it may be. I think I'm more interested in finding out a solution rather than trying to point a finger at a manufactuer/distributor right now.
            These boards seem deformable by nature. I just don't want to procede with my construction unless I feel comfortable with the foundation.
            Sorry to be obtuse, but that's where I'm at.
            I have a little experiment going with a couple of hundred pounds of weight vs. 4 slightly deformed boards.
            I'll report back later!
            Freak
              Asking the product you are using was not intended to point fingers. It was intended to help solve the problem. Good luck on your experiment.
              Do not meddle in the affairs of dragons, for you are crunchy and taste
              like chicken...
              My 44" oven in progress...
              __________________________
              http://www.fornobravo.com/forum/f6/s...ally-6361.html
                Agreed CK, If there is bad product out there, it serves our group well to avoid it. Then again, if he solves the problem - it's all good
                Les...
                  No intension here to be critical. We're asked about a lot of products, and most of us have only direct experience with one (in my case, insblock19). The more we know about specific products, the more we can help you, and future builders in those cases where we haven't run into that specific product before.
                    If the product is deformable, I could imagine that moisture contributed to the deformation - We have one member here who had a bad experience with one type of insulation board that turned to mush when it got wet...
                    This is a pretty cool forum - and about the best bunch of folks I've ever had the chance to be on a forum with. We are all about helping each other be successful.
                    Christo
                    My oven progress -
                    sigpic
                      Pretty great bunch of folks is right. Forno Bravo Forum, 4700+ smiling faces and a few old grouches.
                      like chicken...
                        My question on this topic is more with regard to the board holding up during laying the floor with the fireclay-sand paste...first experience with the stuff and in starting today...the few bricks I had to re-lay came up with clay on them but the clay also took up a bit of the board...anyone have like experience?
                        Any input is greatly appreciated!
                        Best
                        Dutch
                          Dutch - I saw that as well. I made the mistake of making a slurry of the clay. When you get that stuff wet, it turns into an adhesive. When I adjusted the brick - it did lift some of the product. All said, level the brick with DRY product.
                          Les...
                            I just put down my floor bricks using 1:1 mix of dry fire clay (reconstituted sludge from bottom of wet saw tray) and sand. I used it dry. It works well.
                            Mike - Saginaw, MI
                            Picasa Web Album
                            My oven build thread
                              Thanks guys...I had done that in the past and was going to do so this time but...thought of the new instructions encouraging the use of a paste...will mis the products dry and move forward...
                              All the best!
                              Dutch
