I constructed my second arch this weekend, including the chimney opening and base plate build up. As I started the second arch, I tapered all of the bricks (which came out much nicer than the first arch with untaperd bricks) in doing so, the sides of the bricks were really smooth. I was worried that with the weight of full bricks, they would want to slide out of place. I decided to use my grinder to cut smal grooves horizontally along each of the bricks. I figured that the grooves would give the mortar a channel to lock into place. It worked like a charm! I've attached a couple of photos...
Has anyone done this before? Was this genius, or a waste of time?
